Opening concurrent windows/projects
Most Windows software like MS-Excel allow the user to open 2 or more files concurrently and allow the user to select which will be the active workbook. Is this a feature in MillMage? If so, how can I set this up?
In MillMage, click on New Window. Same as Lightburn. I do this a lot on both. I copy/paste back and forth as needed.
YOU CANNOT control the same machine with two windows. You can only control one machine.
Just discovered the solution to this problem.
I always work in Full Screen mode. In MS-Excel, there is a menu selection (Windows) in the Menu bar that shows the names of the open workbooks and allows you to select which one moves to the front.
In MillMage, the above feature is not available. You can open multiple project windows but you will only see the TOP window in Full Screen mode. When you reduce the top window from Full Screen mode to Window mode, the other project windows will now be visible.
I stumbled on this one while trying to solve another issue.
Thanks to everyone for their input.
