Is there an easy way to layout multiple parts in lightburn as at the moment I’m doing it by trial and error to come up with the most compact layout?
It depends on how complex and different your parts are.
If it is only one or 2 different pieces, I anange them manually and use the array function to fill up the entire workspace. If there are many different subjects, use “Nest Select” in LightBurn. It takes a little practice but works quite well.
Cheers using “Nest Select” looks like it will do the job .
Thanks
