I may be overlooking it…or maybe it doesn’t exist. I need to engrave an oval 3mm thick ring offset within the perimeter of a 203mm x 95mm oval. When I run it, it takes over an hour to do this very simple engrave because of the back and forth, straight-lline travel. I’ve looked at the optimization settings and cannot see a setting that tells the laser to engrave following the contour of the ring. Am I missing the setting? Or is Lightburn not capable of performing the engrave in this manner? (see pic)
dustboot2.lbrn2 (42.3 KB)
