Hi, could it be possible that the optimization settings will be saved with every file?
Or to have an option so save/open different optimization setups?
We are working on several enhancements to the saving of more settings in the LightBurn file. āOptimization Settingsā is on that list.
Hi Rick,
Thanks for confirming my request of last February is being picked up.
Keep up the good work.
I just this evening submitted that code change to @LightBurn You will be able to save all those settings to each lbrn project file (you have to turn on that option though) and the optimizations dialog now has a āSet as Defaultsā button that saves them globally (instead of always saving to your global prefs anytime you change them).
Should be in v0.9.10
