I’m not familiar with the optimize settings… How do I set the parameters to get the cutting start from the bottom upwards one line at a time. When the first line is finished at the top the hed should move to next and begin cut the line downwards, and so on.
(Maybe I write this in wrong category?)
If I understand you correctly, you want the entire bottom row to be cut first bidirectionally.
There’s a setting for that specifically. You can group the sections and set them to have orders of priority. That would allow you to group the bottom row and set it to the highest priority and it would all get cut together before it does anything else. Then you would group other sections and do the same, reducing priority as you go for each group.
Here’s the Tutorial Video for Cut Planning
