Hello! I want to make some cutting of vertical and horizontal lines. Because i have a diode laser it cut my material with 1 pass on the Y axis but need 2 passes on X axis. So i made 2 layers, same speed and power but different passes! My question is why it makes so big moves on the X axis when moving from a line to another, while on Y axis it’s just jump to the next line. Can i change it?
If i make all in 1 pass is ok, so i can just redo the 2 pass separately, but i am looking for a more direct way!
Thank you!
I believe an easy way is to create a sublayer within my C00 layer
