I have Microstation as my CAD program, I created a drawing that I want to import into Lightburn but nothing shows, all I get is the blank window
What format are you using to export from Microstation?
Are you able to share the export file here to review? You will need to add a .TXT extension for the file to be accepted on the forum.
I exported it as a DXF file
Most DXF should import fine but does have certain limitations with specific features. Won’t be able to help more without any more information about what you’re seeing or dealing with.
After the import click on
‘zoom to selected shape’…
