Origin On Computer
I am currently experiencing an issue with my Lightburn setup across two computers. I use one computer for designing, while the other is connected to the laser.
The computer I use to create the artwork the origin appears correctly positioned next to the drawing. However, when I send the file to the second computer and attempt to print from the second computer, the origin does not move from the top left corner of the Lightburn workspace.
Could you please assist me in resolving this issue?
I found the issue. Still very new to Lightburn. Somehow the Start From drop down changed on the computer. I change it from Absolute Origin to User Origin, and the problem is gone.
Make sure both PCs use the same preferences:
Be aware, the “user origin” is not a defined position. Once you set it somewhere else, the process will change. Use “current position” if you do not exactly know what user origin does :slight_smile:
