i test my images on small material once i get a good setting i enlarge the image and it turns out darker, i know im missing a step can anyone help. tyia
It’s not a good strategy to test parameters on a strongly different object size. You will have different speeds, most likely. If you have a line of 10 mm and another of 100 and you run them at the same speed, you might get a different acceleration and deceleration curve on those lines (depending on a bunch of settings like overscan etc.) and the result will be different. So take physical capabilities into account. And if it’s a natural material like wood, you won’t have the same result on another piece of it as well…
I thank you for responding, i believe i figured it out. I downloaded a good photo editor and can change sizes easily and resolution if needed.
