I purchased the new Ortur Enclosure 2. It comes with a light and fan. I turn the light on and then the fan but when I start the burn the fan turns off and won’t come back on until the burn is done, then I can turn it back on…
Any help would be greatly appreciated…
I’m having the same issue. I just updated Lightburn software and Ortur firmware.
Did that help?
Unfortunately it did not. I’m hoping that someone else can chime in since your message was set to lock after 30 days.
Yea, it’s disappointing not to have the exhaust work
Ok so Ortur Tech support suggested the following…
“Can i ask
a) please update to 1.9 firmwre
https://ortur.tech/firmware/OLM_Series/OLM2_PRO_S2_Firmware_Release_1.90.zip
then in lightburn
b) Edit → device settings can you change air assist to M7 instead of M8 please?”
This did not work for me. BUT I was able to make it work.
I have my Macro buttons programmed for light on/off and Fan on/off. I now have my FAN ON as “M7” and FAN OFF as “M15”.
This seemed to work for me. I hope it works for you.
Thanks, I’ll give it a try…
Did this work for you?
Change on edit → device settings
Air assist from M8 to M7 that should fix it
Make sure you are in 1.9 for OLM2 pro And OLM2 S2
or OLm3 207
