The result is way under whelming. I tried to focus the laser. It is a small rectangle but doesn’t seem as focused as it could be. See below. Is it me or my laser?
Greetings
Can you tell me please what is the distance you are using rom the bottom of the heatsink to the material?
Also what speed and power on the test?
Your focal distance is a bit too far
From the bottom of the heatsink - not the knob - to the material it should be 35mm
Also i would recomend changing your lightburn settings from mm/sec to mm/min in Edit -> settings -> “Units” Better for diode section
Restart
it should be in a notepad document titled FAQ in the FAQ folder nested in the LaserMaster2 folder the third set of “answers” has the focal distance for the three different power diodes Ortur sells
