Just got the Laser Master 2. Assembly and setup was easy. When trying to Home it and start things up, I’m having problems:
Waiting for connection...
error:9
Homing
ALARM:8
ok
Ortur Laser Ready!
Grbl 1.1f ['$' for help]
[MSG:Check Limits]
[MSG:'$H'|'$X' to unlock]
[MSG:Caution: Unlocked]
ok
So I’m not sure what’s happening. I’ve looked up GRBL error:9 and ALARM:8.
“error:9” : _(“G-code locked out during alarm or jog state”),
Ok, that make sense that it won’t do anything in an alarm state.
“ALARM:8” : _(“Homing fail. Cycle failed to clear limit switch when pulling off. Try increasing pull-off setting or check wiring.”),
Ok, so the laser is in the middle of the cutting field, so neither the x or y limit switches are being touched. I checked the wiring and everything appears to be hooked up just fine. (I mean, it wasn’t hard…)
The board is alive and responding:
$0=20
$1=50
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.050
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=7
$24=600.000
$25=3000.000
$26=100
$27=2.000
$30=1000
$31=0
$32=1
$33=250.000
$100=80.000
$101=80.000
$102=80.000
$110=9000.000
$111=9000.000
$112=9000.000
$120=2200.000
$121=1800.000
$122=2500.000
$130=400.000
$131=430.000
$132=1.000
ok
Also, because I just got it, I am assuming the firmware update 1.34 is already installed, as $110 through $112 already at 9000.
I’ve read through the other posts and they seem to be focused on the firmware issue, but this shouldn’t be it: I just got it and it is already applied.
Any ideas on what I should check next?
