When I power the machine on, it tries to home but bottoms out in the lower left and keeps banging like it’s trying to go past the limit switches. Been using the machine for a while. Leaned the laser eye today so I had to pick the front up to see it. Worked fine before.
Waiting for connection…
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S2]
[OLF: 190]
[OLH: OLM_ESP_PRO_V1.2]
[SN: 317194920D33AF6796E2AFFD863C85C8]
[OLM:GENERAL]
[DATE:15:24:15 - Oct 14 2022]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,35,7680,3]
Target buffer size found
ok
Homing
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
Ortur Laser Master 2 Pro S2 Ready!
OLF:OLF 190.
OLH:OLM_ESP_PRO_V1.2.
OLM:GENERAL.
[MSG:Warning: Flame Sensor Disabled by User OverRide]
[MSG:Flame detector active,Ambient infrared value:0]
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
That means the laser head / gantry aren’t activating the home switches, which the Alarm 9 error confirms.
Look carefully to find loose switches, tangled cables, bent sheet metal, or anything else that’s getting in the way. With the power off, move the head / gantry slowly toward the switches while feeling for any resistance, then fix whatever you find.
The Troubleshooting tips may help:
Red wire had pulled off… figured it had to do something with the machine itself. Thanks!
That’s a new one … ![]()
