Ortur Laser Master 2 settings HELP!
For whatever reason when I’m trying to jog or laser anything, I try and set my speed up and it never increases. It’s as if it is set to one speed. It stinks because something that should take me 4 mins is taking me 40. Can someone help me with the settings? I might have gotten something wrong during the set up. Thank you!!
In console, type $RST=*
Press enter
(This sets all settings to default)
rehome machine and try again
When you say, “whenever I jog” - the speeds for jogging moves are set in the ‘Move’ window, here: Move Window - LightBurn Software Documentation
That’s independent of the speeds set for cutting / engraving, which are set per layer in the Cuts/Layers window: Cuts / Layers - LightBurn Software Documentation
So if Gil’s suggestion doesn’t change anything, check those things, and if you’re still having issues, reply here.
That fixed my speed problem now when I run my laser it starts acting crazy and sounds like it’s catching on something but it’s not.
Uploading: image.jpg…
Please edit this post ^^. Let the picture completely upload prior to committing this post. The image did not load fully. :slight_smile:
