Ortur Laser Master 2 Stop working after 40 minutes of engraving, is there’s any setting to fix this. The timing still running and it said that is busy, but the laser is not working. I am new to laser engraving.
Hi, fairly new to this too but the more info you can give them the more likely a response.
the quickest way would be a snapshot of your lightburn with the settings and type of project and what windows you’re using.
Could be you just got disconnected but i’m sure someone will be able to help at some point.
As of my own experience, this is caused to disconnecting problems.
Check if the cable is correctly plugged in, check energy savings option for USB on your PC.
I had the same problem but it was caused by a shacky USB port.
