Ortur Laser Master 2 - Y axis won't move
The laser bar stops at the (0,0) coordinates. I tried tightening the straps on both axes but nothing helps.
The right-hand side of the bar seems to keep moving while the left side stops at the switch and it makes a buzzing sound. I made sure all the wires were seated correctly too.
Please advise.
Sounds like it’s failing to detect the limit switch on the axis of overrun. Check switches and connectors.
Does the console give you any kind of an error message?
