Ortur Laser Master Pro 2 not moving to job, stops movement imediatly
When I go to start any job the laser moves from home and stops immediately, when i press the frame button the laser moves in one direction only and stops very quickly, my home is set to bottom left the laser will home OK.
error:9
G-code locked out during alarm or jog state.
[MSG:Caution: Unlocked]
I don’t know what this means;
[SC7A20:(50) Shock and Movement detected! Check TroubleShooting Section in User Manual.]
Ortur Laser Master 2 Pro S2 Ready!
OLF:OLF 185.
OLH:OLM_ESP_PRO_V1.2.
OLM: GENERAL.
[MSG: Warning: Flame Sensor Disabled by User OverRide]
[MSG: Flame detector active,Ambient infrared value:0]
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
Here is an excellent post about this issue
Thank you I will try this
Is there any way to go back to a previous setting, I am having a lot of problems since I uploaded the latest version.1.2.04. still got a problem with flame detection in spite of shutting it down, I cannot frame a job without the machine stopping half way through,
