I get an out of bounds message every time I Start a project. Selecting OK does start the engraveing but it is rritating
Any suggestions?
X Tool D1 Pro
This is suggestive that your operating procedure is breaking known position on the controller.
Can you validate the following:
- Your machine is being homed at the start of operation
- You are never manually moving the position by directly manipulating the laser by hand?
- Similarly, you are only using jogging controls in Move window to change laser position
- Confirm the Start From mode in Laser window that you’re using. I assume Current Position or User Origin
If none of these apply then can you take a full screenshot of LightBurn with a design loaded where you get this issue?
