Out of Memory error
Hello, I keep getting an error when trying to send an image over to my laser to burn. It gets to 20% and then a popup comes up and says “Out of memory attempting to rasterize image”. I have plenty of memory on my computer (Running 64gb of ram). Not sure what to do? DPI is only set at 240 and the image is a 6 inch x 6 inch tile.
Thanks for the help!
Hi Ryan, have you tried clearing the memory on the controller?
Mine is a ruida but if i have a lack of memory on the controller i usually get a message on the computer telling me and doesn’t allow it to send but worth a look.
Need some additional information, if you will. Are you using the 32 bit version, by chance? That has less access to continuous memory than the 64 bit version does.
Is the 6x6 a grayscale image, or just dithered? (Dither uses less)
