Output scale is off
Hey all, 1st post. basically just getting started with my laser and doing some testing for my 1st project. Ive done some playing around with the laser but just basic marking stuff and never checked output scale till now The output/marked scale is to large. If I make a 1-inch circle and output it’s about .270 to large so 1.270 Di. My preference is to work in inches for artwork inside LB but settings for F&S im ok with using mm settings since I know this industry usually uses mm/sec for speed settings. I get the same results with the project file that Im working on. This file is coming from CAD software as a DXF and the size is 1.373 in CAD but when marked it is 1.73 in diameter.
Strange that the output is off in scale because I thought I had everything set up correctly. What is going on here?
You didn’t load the configuration file when you created the device…
Every lens has a different correction file…
Mine was markcfg7, supplied by the manufacturer and on the usb stick that came with the machine.
Is this new?
Right I do remember this from the 1st video for Lightburn crash course from Alex at Laser Everything, BUT actually, the owner of the company who I bought the machine from helped me get the machine up and running when I set it up. Sounds like he forgot to do this?
Yes machine is new, set up about 2 months ago but just getting to learning it now. I never checked the output scale when he set it up.
I can rewatch the video but can you point out where to load the config file?
Just click on devices in the laser window… Click the proper device and edit.
Enter what is needed, skip what you don’t want… it retains it if you don’t enter anything.
Click through it and it should be update…
Look on the usb stick that came with the machine… I copy mine to my machine, then when I do a backup, it’s included.
Good luck
Pretty strange, but the configuration was actually all set up, I never changed anything since Andrew from Lasers Only set up the machine for me. BUT there was something wrong with that setup.
I made a new lens config file, did a test and the scale is fixed now. Strange cuz the work area size was the same for both config files.
Don’t know what this affects internally, but the size comes from these files and with new lenses, I’ve seen some strange work areas come out of the software…
Did a lens with one of videos using Lightburn for lens correction. It was a pain, did the last two, stealing the spouses Windows machine and use EZCads CoreFile2 software… much more simple, but you can’t change something like the work area or coverage…
You can see where these items are grayed out and the coverage, for an F254mm lens is 175mm square… Notice width and height…
Glad you figured it out… Mark the thread solved, whichever one was the resolution…
Have fun
