hi for some reason when i click frame no matter where my work is on the work area the laser still moves outside the work area even if the design is in the middle of the
work areawhat are you origin settings?
You have not said what type of laser, controller/firmware, OS, Version of LightBurn nor any of the settings you have within LightBurn. You can save some this information in your User Profile so asking for this info won’t be required for each issue you post. You would only then need to post current settings for a given issue.
That being said, you haven’t provided enough info for us to be of help. Please do so.
As a guess, if you are running a GCode system, and have your origin set in the rear-right like that, you’re probably running in negative workspace coordinates, which LightBurn doesn’t currently support. You can easily set a workspace offset to fix this: https://github.com/LightBurnSoftware/Documentation/blob/master/CommonGrblSetups.md
