tsurra
(Terry Surra)
1
I am experiencing over burn on graphics that i have used before. I have an Ortur master 2 15w,
it is using GRBL-M3 (file or earlier), attached is a snap shot of my console
here is and example of what it is doing now compared to what it was engraving
When I open and engrave this file there is no problem with the engraving
Thank You for any help
For the Ortur you should be using GRBL, not GRBL-M3 (you can go to the Devices window, double click it, and change it through there).
The problem is likely that you don’t have Overscanning enabled in the Fill settings.
tsurra
(Terry Surra)
3
When I go to the Device window all I have is GRBL-M3, how do I get GRBL.
In my example of the graphic that is engraving without any issues i don’t have Overscanning on, but I will make sure that I start turning it on.
Thanks
tsurra
(Terry Surra)
4
Got it, I did a Devices, Create Manually and found GRBL in the list.
Need to test things now…
Thank you for all your help.
system
(system)
Closed
5
