Panels layout in bundle/preferences file?
Hello! I’ve just installed LightBurn on a second computer, and I’ve exported and imported a full bundle to synchronize the settings and internal data (even though the second machine will only be used for design and not actually control the machine).
However, I found that it did not also import the panels layout that I had set up on the other computer. I also tried exporting and importing a preference file, to no avail.
Is there any way to synchronize the panels that I may have missed?
Thanks!
I don’t have the answer as far a s syncing automatically. Do it manually. Go to the File menu and enable anything that isn’t and needs to be. Disable any that you don’t want. The panels can be repositioned easily if they are not in the position you want them.
Yep, that’s what I did, as it’s pretty quick to do, as you point out.
I was just curious as to why it’s not part of the settings bundle, as I would expected it would be, and wanted to make sure I wasn’t missing anything obvious. :slight_smile:
Thanks!
Perhaps the window arrangement depends on the screen resolution: what works on this PC won’t fit on that PC’s monitor, so it gets rearranged to suit.
