Parameter changes not reflected without saving file first
I updated to 1.5.02 late yesterday afternoon. This morning I come out to engrave some glasses on my UV. Windows 10 Pro, Pascal 5w UV, nothing else done except update to 1.5.02 - PiBurn Omni rotary.
Two things I noticed…
  1. LI doesn’t seem to have any effect when changing it unless you actually save the file first. I changed from .030 to .025 to .015 to .010 and no difference in engrave. Then I saved the file and it corrected itself. Changed it again and saved file, corrected. Changed again and did not save file, did not correct itself. Tried on several files I’ve used religiously for glass engravings for over 2 years.
  2. Scan angle - same as above. if I change it on a live file, even in preview it doesn’t change angles. If I change it, then save the file, then preview it’s correct.
@twedlake can you please please goto Help > Generate Support Data and paste that info here?
Could you also provide the project file you were using?
I am unable to reproduce what you are describing even with a galvo device and rotary enabled. If I change any settings they are immediately updated when I run a test or generate a preview.
will do sir when I get home later this afternoon.
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
glasses.lbrn2 (98.6 KB)
@twedlake Please note I’ve moved this to a separate forum topic to keep it all together.
I unfortunately still cannot reproduce what you are seeing. Let me know if what I’m doing in this screen capture is not what you are actually talking about
Hey there… sorry for delayed response, got stupid busy.
I reverted back to 15.0.1 and the problems went away… this is ONLY happening when in rotary mode I discovered later on after my initial post.
Also I can duplicate the LI and scan angles in rotary mode only with 15.0.2. Everything else works fine.
I hate to ask but any chance you can capture a video of this happening?
I can’t replicate it in any version and after checking the code there’s absolutely no reason any of this would be different in 1.5.02 vs 1.5.01… so I’m incredibly stumped. Maybe seeing exactly what you are doing would help.
hey Adamm. Let me get through the next week or so of these UV and Fiber jobs and I’ll be in a place where I can reinstall 1.5.02 and capture video for you. If you’d like, I can just submit it via a support ticket.
That would be great. Just please note that you did back here :slight_smile:
