Hello,
I use GRBL 1.1e. During an engraving, I pause, I change the speed of movement or the power of the laser, input.
I raise with Pause, nothing changes.
Do you have an explanation?
Thank you
When you click the ‘Start’ button, LightBurn generates the entire job as GCode, and stores it in a buffer in memory, then begins sending it to your controller. Changes you make from that point do not affect the current job so you can load a new file and begin preparing for the next thing you want to send to the laser. Pause is only pausing the stream.
