Parameters are flipped
Hello,
I have set the Origin and Job Origin in Lightburn in the lower left corner. When I press the Home Button it goes to the upper right corner. When I jog the laser head using Lightburn everything is opposite. When you select the Up Button the laser head goes down and so on. When I run a program everything seems to be “flipped”. Any ideas on what can be done.
Change the machine origin in LightBurn Device Settings. If your machine homes to the upper-right then set the machine origin to the upper-right.
Ok. I will give that a try. Thanks!
Generally, if your machine ‘homes’ you don’t have any choice where ‘Origin’ is… that’s what Lightburn needs to know…
