Parametros de grbl (grbl parameters)
Hola buenos dias, recien monte en k40 chino placa mks cnc32 quisiera saber los parametros que hay que poner porque no me hace el grabado bien creo que es por la configuracion
Hello, good morning, I just mounted a Chinese k40 mks cnc32 plate, I would like to know the parameters that must be set because the engraving does not work well for me, I think it is because of the configuration
It would be best to start with the parameters you are using, the results you don’t like and adjust it to what will work best for your particular set up.
Which Speed in mm/minute and what % Power are you working with?
Please share a picture of the work you have tested.
Please also, open the Console window in LightBurn and request a settings report by typing:
then press enter.
When you copy and paste the report from the Console window in LightBurn into a reply here, it is my hope that we can see the settings that are creating the unanticipated or undesirable outcome.
El ciclo de inicio no está habilitado en los ajustes de Grbl.
The startup loop is not enabled in the Grbl settings.
$0=10
$1=25
$2=0
$3=1
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=1
$21=0
$22=0
$23=1
$24=300.000
$25=1000.000
$26=250.000
$27=1.000
$28=1000.000
$30=1000.000
$31=0.000
$32=1
$37=0
$39=0
$38=0
$40=0
$41=1
$100=80.000
$101=80.000
$102=80.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=6000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=500.000
$121=500.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=285.000
$131=272.000
$132=80.000
$133=300.000
$134=300.000
$135=300.000
ok
$22=3
No obvious problem so far.
We still need to know the commanded speed in mm/minute and % Power that you have requested for your engraving operation.
I would also like to see a picture of the attempted artwork. Occasionally the materials that are selected create an unpredicted obstacle. :slight_smile:
