Parametros para grabar metales o cristales
Hay alguna pestaña o forma de editar distintos materiales en lightburn?
No consigo grabar en metal ni en cristal y tampoco consigo cortar metacrilato o acrilico.
Is there a tab or a way to edit settings for different materials in LightBurn?
I’m unable to engrave on metal or glass, and I also can’t seem to cut acrylic (methacrylate).
You can utilize the Material Library after you add the settings you wish to use for each of the materials.
Your Bio says Hobby TwoTrees laser, so I am guessing it is a diode laser. That laser type uses a visible blue light, which goes through glass and acrylic. The only metal you can engrave (mark) is stainless steel. All other metals conduct heat too fast.
To etch glass, you must coat it with something that can absorb the laser beam and micro fracture the glass.
You can sometimes cut or etch acrylic that has a solid color close to red in a color wheel.
