I have a set of boxes I use as a template for cutting(I snap my work pieces to it so they’re perfectly lined up). I was working on lining them up to eliminate any extra lines, however whenever I copy and paste it, part of it shifts. It does NOT matter if they are grouped or not.
If I use “Duplicate” it does not shift. But “Copy and Paste” shifts every single time. For example, I will copy a group of squares/rectangles that total 19" x 5.25". When I copy and paste it becomes 19.0002" x 5.25" or 18.9998" x 5.25". I tried remaking the problem shapes from scratch, but its still doing the same thing, or shifting .0002 in the other direction.
Now another issue I discovered. I just saved the file, thinking that maybe I need to restart Lightburn. However when I reopened it, the shapes in the template that were perfectly aligned previously had shifted. The items that I placed on one of the duplicated templates had also shifted, but not in the same way the template shapes did.
Any ideas for how I can remedy this? Have I unwittingly changed some odd setting somewhere?? I’m slightly freaking out. I’ve never had this happen before, or at least I’ve never noticed it.
Sam
