Ruida Controller/ Windows
If I set the Pass Through Option for an Image, the interval settings in the “Cut Setting Editor” (double clicked the layer) is grayed out, which makes sense to me since the interval should be determined by the image resolution.
But in the “Cut Info” window under the cuts, the interval edit box allows new values to be entered, and any change to the interval here updates the interval edit box in the “Cut Setting Editor”.
Does changing the interval override the Pass Through option or is the new interval just ignored?
