I have been struggling with this for a couple of days now and can’t figure out what is going on. Below are pics of the design I am trying to engrave. If I put the text and constellations as “fill” then everything seems to shift to one side (except for the line frames), but if I switch everything to “line” then everything lines up exactly as the design is shown on screen. I can’t figure out what is going on. Any help would be appreciated.
This all looks fantastic. Maybe a little bit of soot or smoke but fantastic.
Can you point out the misalignment for me. There are two or three things it can be. I might be able to help you narrow it down by knowing how much it goes out of alignment and where it happens.
There are a couple of points of technique that can cause problems like this.
This particular case is more subtle than most.
Are you willing / permitted to share your LightBurn file publicly on the forum.
If it’s proprietary / private you should be able to DM it to me and I can take a look or you can email it to Support@lightburnsoftware.com with a link to this thread and someone at LightBurn will be able to review it.
