I have started engraving images on painted ceramic tiles.
I turn it greyscale> adjust curves > adjust brightness contrast > unmask image > bitmap with haftone round patter.
I am getting a weird pattern sometimes on the engraving which I have added a picture and it shows this pattern on the one shoulder.
Not sure where this is coming from as it doesn’t show up in photoshop or lightburn. If anyone knows where it is coming from or how to fix it would be much appreciated.
What’s your DPI? Settings? Post the original picture? Does it happen with every engrave? Does it never happen with certain pictures? Have you cleaned off the tile?
That looks like vibration from the belts, often referred to as ‘curtains’. You can usually fix it by adjusting the belt tension a little - I had this on my large machine and tightening the belts a bit made it go away.
Did you enable pass-through on the image setting? If you’re dithering or converting to halftone in external software you should turn that on so LightBurn doesn’t resample the image for you.
LightBurn Oz, how much did you turn the bolt when tightening the belt. I did the X axis belt a half turn but still have the pattern and am not sure if the belts can be over tightened.
There’s a sweet spot between too loose and too tight that you’ll need to find. On my own system, having the belt very tight produced the same curtains as too loose, presumably because both conditions cause the belt teeth not to mesh well with the pinions, which induces vibration.
So I tested different brands of tiles and also a glossy paint and a flat paint. What seems to have worked was to drop the DPI to 254. So far it is working
