Pause between groups?
The last batch of plywood I bought is very temperamental and often warps, pops out and gets in the way of the head destroying most or all of the job.
These jobs are often several copies of the same object repeated 2 to 50x depending on the job.
Is there a way to get Lightburn to pause between groups (not layers) so that I can inspect and/or remove a cut piece so that it wont get in the way of the head?
If not, can a mod convert this post into a feature request.
You can select the first 30 or so and then continue with the next series. I think it’s called “cut select shapes”, I’m not at my LB computer right now. But it works fine for me.
Ah yes, this rings a bell. I just hope it does not reset the origin between each one. Gonna try it now. Thanks!
With absolute coordinates I have no problems with this type of production. After each group the laser goes home, up to the top left and everything starts over.
I use relative and it still works. Thanks mate!
