The “Pause” does not restart in v2.1.02. Must “Stop” and start all over again, wasting all the work done.
Not necessarily the answer you seek, but a work-around until the answer appears. After you have hit Stop, use the preview feature to advance the indicator to the point at which you stopped. Use the “Start here” button to pick it up from there. You may have a bit of overlap or a skip, depending on how well you can identify and match the cut off point.
For what type of laser / controller?
Machine: Two Trees TTS 55 Pro with a 20w head
Are you clicking the pause button, when you intend to click the ‘Resume’?Job Control - LightBurn User Guide
