One more PDF question. When I import a pdf file in Light burn the line widths have no stroke width like the original document. Does light burn not recognize stroke widths in a PDF ? If I open the file in Acrobat or any other program the stroke widths are there. Am I missing some setup parameter ?
LightBurn does not use line width at all, from any file type. A line is infinitely thin, so if you want to create a wider mark than the width of your laser beam, defocus the laser or add an outline of that line and use the ‘Fill’ setting.
