Pegs to stop Honeycomb burnback
Hi Folks.
With my large laser I often find I have issues with burnback from the honeycomb. So I decided to make a little peg that slips into the honeycomb and lifts the work about 3mm off the bed.
I use PLA and with one every 15cm it holds the board off very nicely.
Air is able to flow across the honeycomb between the work enabling a cleaner better cut.
[Here is the Link for the STL]
(https://drive.google.com/file/d/1rL6KhIEPp1GDaKI75lCf13XzBztT4QKc/view?usp=sharing)
Enjoy
Dave
I ended up ditching the honeycomb entirely. I use a steel peg board and magnets to lift the work off the bed. Side bonus is that the magnets hold everything flat and the “peg” holes are precisely an inch apart - making approximate placement easy, and precise repeatable placement using jigs fitted into the holes simple.
Final bonus, a steel pegboard from home depot was cheap ($15), available locally, and less 4mm short of my available work space - so I could use the laser fixed to the spoiler board to cut a cavity for it - ensuring perfect alignment.
Great idea for smaller lasers. My bed is 1300 x 900 and I use full sheets of ply.
I didn’t last too long with a honeycomb bed, either. I put a sheet of metal in mine cost me $12 USD. Marked holes with the laser and drilled them. They hold my jigs (5mm sub flooring) and the steel collects lots of the debris and wipes off easier than honeycomb.
:grinning_cat:
Hey David, what is PLA ??
PLA is an inexpensive filiment used in 3D Printers.
OK thanks. I don’t know how I got in the 3D group.
You’re not… he advised he 3dprinted something for raising the material above the table/honeycomb.
:grinning_cat:
O ok good. :slight_smile:
