Pen rotary on galvo
Will there be support added soon for rotary tables? That would be a rotary positioned with the shaft in the Z axis. The rotary doesn’t turn while engraving, but instead rotates a set angle after each mark cycle as seen in this video:ABS enclosure marking on fiber laser - YouTube
Repetitive marking is a large part of what I need my fiber to do, and most of it is done on a rotary table. EzCAD does this with RotaryMark2, but I can’t find any way to do this in the LB Galvo rotary setup. Maybe under rotary setup you can add an option for a Z rotary axis that will present these settings?
I inquired about this during the Closed Beta, and was informed by Oz that this is on the list of features to be added in the future.
