I have used the pencil tool before while turning off snap to objects to draw around an object, then edit it with node editor. Worked perfect. Now I cant get anywhere with tracing an object with the pencil. The line just disappears when I let go of the mouse button. It’ll draw a line, but it goes away when you let go. Any help for this newbie would be appreciated.
How are you using the tool? Try this:
- Select pencil tool
- Click once where you want to start drawing making sure you release the mouse button after the click.
- Move to second position and click once, again releasing.
- Continue until you are done drawing.
- Then finish by either closing the drawing by clicking again at the starting position or by pushing Esc key.
Does that work?
