Perfect Alignment Producing Unaligned Cuts
Ideally when you do alignment (alt-3) for print and cut, Lightburn would provide output describing the deskew angle and amount of displacement from proper target alignment (probably expressed in x and y distances).
My concern was specific to handling of images. I do not have any cut vectors with these cubes.
The vectors that were used as the targets and the jig was what I had in mind, I wanted to make sure the fill boxes (to represent the images) were transformed in lockstep with the jig linework.
Are you using Alt+3?
Please use Alt+4 (no scaling), scaling will change the output size which would ruin the jig!
I was just thinking, since I know you are trying to get to the bottom of this, to help you troubleshot you can probably save the Print and Cut Mode output as a .rd file and import it back to the drawing (as a backplot of sorts) and if you group and lock the original artwork, then rotate the import to match you should be able to compare the output as an overlay.
I think you would definitely find it better to align your jig using a more traditional approach for example;
  • push the jig into a corner and then cut the jig internal cutouts
  • push a corner jig-alignment-tool into the corner and cut an L-shape from it using the laser, use this align all your jigs to a known position.
  • marks burnt to masking tape on the workbed and the jig aligned to it. (I prefer this method as it also prevents any potential for small deviations in homing to affect job position)
What kind of scaling will alt3 do? The two options don’t seem to be documented.
If 4 is preferred why is 3 first? This would be an example of an interface failure. The implication as currently set up is 3 is normal and 4 is an exception.
The interface is responsible for directing human behavior, not just providing a dump of options that could be used.
Hi Asher - The scaling will be applied to the entire job based on those two points. A diagonal scale in X and Y.
The options are all presented at the same time, scaling/no scaling listed right in the menu - selecting the correct option for your specific use case is important. The interface is absolutely responsible for presenting the options available, it is on the user to understand and select the correct option.
I’ve requested an update to our docs team to add more details regarding the difference between what scaling vs no scaling means in the Print and Cut context for those whom it is not clear.
Docs are useful but the interface should explain itself. Really there shouldn’t be two options— in the case where the displacement is significant, the application should prompt whether the user intends to scale.
Given two options, the intended default should get priority in the order, particularly in the sequence numbering. The intended options should be 1,2,3 not 1,2,4.
Language and conventions matter. They are not simply arbitrary choices to be decided any which way. The ordering of the interface is a choice about communicating how it works.
I will relay that to our dev team, thanks for your input!
You should apply for a customer service position with Lightburn :slight_smile:
You could use the Hotkey Editor to set your commonly used options to 1,2,3.
ALT+4 could be the reset;
Or the interface could be corrected
You have to be one of the most humble LB users :slight_smile:
“I do not think that word means what you think it means.”
Print and cut seems to have irresolvable bugs that no one wants to address. The solution to alignment seems to be: don’t use it.
Way to go providing broken features.
