Perforated edges when cutting - DOT/Perf/Auto Tabs are off
Hi all,
I’m having problems when cutting materials, at all powers, on my Aeon NovaElite 130w. I can slow the unit down to mask the fact, however operating at the speeds I am (S:40mm/s x P:70%), my 80w Red&Black doesn’t show this in the slightest.
The line style seems to pulse, as opposed to cutting a consistent line.
Any ideas?
File:
perf edge file.lbrn2 (264.0 KB)
Tell me this is not the same machine we’ve been screwing around with for the past couple of months …
If it is, then you know what the problem is already.
If it’s not, then … do all the same checks we did on the other one, because that’s exactly what we’d recommend again.
:slightly_smiling_face:
This is the exact same machine, however, as the issue appears to be different (in my mind pulse timing or something along those lines) I am looking to this group, for support (here’s looking at you smarty pants - oh to have your knowledge…).
If it’s as simple as ‘the TEM00 resonance mode will give this exact result - it is the bulb’, then that’s great! :tada:
If not, I assume this post is fair game?
Well, let’s put it this way: when you know the engine in your car is missing a couple of pistons, asking why it makes a funny rattling noise when you back it out of the garage seems kinda pointless.
Defective laser tube is defective, OK?
Deal me out. :spades:
Poor example. I’ve had my 80w laser with a tube that was out of resonance which gave no perforation style edge quality.
What’s with all the sarcasm?
You realise that having a lot more knowledge than most, means people come to you for answers and support, not to be made to look like a fool.
Poor show.
Well, look at it from the other side. After a couple of months of painstaking debugging, we figure out what’s wrong.
A day later, you ask what’s wrong with the same machine, without the courtesy of mentioning the previous effort.
If you’re willing to call it square, I will too.
Fair enough?
I can absolutely agree to that :white_large_square: :+1:
