Persistent GUI issues
I had this issue way back when I first started with millMage. After a long hiatus from my machines, It seems to still be there.
If I Window/Reset to Default layout, it’s fine for a bit. Then when I go to move the machine it’ll start glitching out after a while, not sure what exactly causes it but I’ll do some more playing.
Laptop, 1920x1080 screen, does it on 100% scaling & 125% scaling.
I’m on 0.8.00 RC-4.
This is a pretty vague description of what is happening. If you are talking about the windows overlap in your images, that is because your screen is too small physically.
You might try full screen mode and Reset to Default.
Windows overlapping is exactly what I’m talking about. Can’t access some buttons. This occurs in full screen mode after resetting to default layout.
No matter what screen resolution is used, this is undesired behaviour. I’d say 85-90% of all consumer based laptops currently in existence are 1920x1080 resolution or smaller. I could probably go on to say that 70-80% of all consumer monitors currently in existence are 1920x1080 or smaller.
All that being said, this ocurred 3 times after resetting to default. I haven’t been able to reproduce it again since.
I had 2 laptops with the same size screen, having the same resolution, and both at the same level of Windows 10. One worked and one did not. It was not Lightburn.
I think the difference was in the video drivers used. One was a Dell i3 (did not work) and the other was an ACER, which did work. Another Dell i5 I have also worked.
Yeah, that is always how it seems to work. :flushed:
