Hi everyone,
I’m fairly new to the world of lasers and have been trying to learn as much as I can, but I’ve encountered a problem with my PHECDA 20W laser on LightBurn that I can’t seem to resolve. The machine works fine for squares and rectangles, but when I try to cut circles or more complex shapes (like the letter “A”), it gets confused and doesn’t trace the shape correctly.
In LaserGRBL, I’ve successfully done both engraving and cutting, and everything works perfectly — circles come out round and accurate (see the attached photo). The perfect circles on the right were cut with LaserGRBL, while the odd, unfinished shape on the left was supposed to be a simple SVG circle cut in LightBurn.
For LightBurn, I’ve only tried cutting so far, not engraving. I initially set up the machine using a configuration file from the Elegoo forums and also tried adding it manually in LightBurn without extra configurations, but nothing seems to work.
Has anyone else experienced this, or does anyone have any suggestions? I thought it might be a mechanical issue, but since LaserGRBL handles both engraving and cutting fine, it seems more like a software problem. I’d prefer to keep using LightBurn if possible, as it’s more convenient.
Thanks a lot for any guidance!
