Phecda changes $3 every Startup
Hi guys,
I’m running a phecda with limit switches on the right (x) and right back (y) sides.
I have to turn off $3 for x and y in the machine settings to make the laser move correctly.
Sadly, every time i start up LB and the Laser, $3 for x and y are turned on again.
How can i make the change permanent?
Best regards
Not sure what you mean. You can’t turn off $3.
Zero is not “off”, it is a parameter binary setting. of 0-7. Did other software come with the laser? The controller may not allow updates using the GRBL command structure except with a special program.
True, it’s not turned off.
It’s just the switch i meant that is directed to “false”.
The laser didnt came with additional software but elegoo sells this with lightburn compatibility so i would expect this to work.
The thing is that it took the change in $23 permanent without any problems.:sob:
I can see where that appears as an on/off. It is really a Bit 0/1 switch. Still, strange you can change $23 and it sticks, but $3 does not. They both use the same binary table for the settings.
Can you enter $$ in the Console and tell me the current value of the $3 parameter. Maybe it will retain if you enter the updated value through the Console window.
Do not try to use this table yourself, at least not for now. I just pasted the table here so I do not have to hunt for it again.
Setting Value Mask
_ Invert____X Y Z
0 00000000 N N N
1 00000001 Y N N
2 00000010 N Y N
3 00000011 Y Y N
4 00000100 N N Y
5 00000101 Y N Y
6 00000110 N Y Y
7 00000111 Y Y Y
