Photo engraving on Slate
Hello!
I would like to ask for somebofdy’s help to get the right setting to engrave a photograph onto a slate.
I have a Sculpfun S9 and I use lightburn to engrave this onto the slate. I’m in a tight schedule and would love for someone who can send me the right setting for photo adjustment and engraving setting.
I usually have the right setting but it’s not working this time round.
Many thanks.
N.
Hi Niamh
Have you tried setting the photo (image) to negative.
Slate usually being dark in colour will burn a lighter colour..As opposed to wood which burns a darker colour.
After that its simply a question of which Image mode gives you the result you want in terms of detail and time taken.
Start with a speed and power setting of your choice and adjust from there til you get it as good as you can.
If you have some material to practice with, you could take (crop) a small section of the picture and focus on that and you could use the Speed/Power adjustments in the Move window to make small adjustments as the image is being engraved…to save time (Note your starting speed/power as you progress.
Also Image adjustments should be noted.
And check your Focus.
I’ve tried that - what setting do you reccomend?
I’ve tried adjusting the image setting and the laser setting. Many thanks
Many thanks
Can you post a picture of your results so far.
I cant recommend because I dont know what results your getting with your machine, material and settings…which are all together unique.
