Can any one give me a hint about this burning on cork
I tried severl settings, but the latest Atkinson Spd 3500 Pwr 60% gives me a picture on the cork. The picture on the LB is lighter than the burned picture
I enclosed 2 pics #1 is on the LB svreen # 2 is burned
I have tried different settings, with no luck…
please advise me
I don’t have much experience working with cork but just from looking at the burn I suspect cork may be a difficult material to get a detailed burn.
Here are some suggestions to try to improve clarity and burn gradation.
- Run an interval test to determine ideal DPI for cork. I suspect cork would require a larger line interval than more consistent materials
- Check out the dot width correction field in the image settings. This is meant to reduce overburn by accounting for the actual size of a burned dot rather than assuming that it’s equivalent to the DPI dot size.
- After tuning the above I suggest trying a different image mode than Atkinson. Looks like Atkinson is overemphasizing the dark tones and losing the mid tones resulting in overburn and losing detail. Perhaps going to a more coarse dithering strategy would work better, perhaps even newsprint or halftone but not certain.
