I made this frame with the offset tool and then added the diagonal’s manually. Is there a way to break apart the frame into the 4 sections so I can cut it to save material? I attached the file as well. Thanks
Frame for 23x15 pic.lbrn2 (5.3 KB)
I don’t know if it does, I am new to this. But you can just use the line tool to trace the four parts. The cursor will show you when it snaps to a vertex point.
Thanks for the tip! That worked perfectly.
Frame for 23x15 pic.lbrn2 (7.4 KB)
Here is the file if anyone wants it.
The way you drew it is fine if you want to cut the whole thing out… Assuming you wouldn’t cut the diagonals. If you wanted a single piece.
I think it would have been easier to draw one, top and side, duplicate them and have the whole frame.?
