Hello,
I have a problem with the LB. When I create a text like “TEST” and burn it the result was a mirror of the original. Is there such a switch in the SW to eliminate this behavior?
Thanks for help.
Hello,
Thanks for help.
You have your device origin set incorrectly. Device origin is the corner that your laser seeks to on power up. Changed in Edit/Device Settings:
For GCode machines, that device origin is almost always front-left, regardless of where the machine homes. For DSP lasers, it’s the homing corner.
Hello Steve,
thank you for this tip. It works!
it’s solved - thank you for the quick answer.
