This is the bit that doesn’t work - I don’t think the system uses the start point of the shape, it uses the first node in the shape, and those aren’t the same. The ‘Start Point’ is just a marker for the cut planner to know where to start. I’ll make changes to the code to make the Copy Along Path use this too, but for now you have to put the shape at the first node. In my case, that’s the upper-right corner.
