This is a plaque I’ve just finished. The design was created in Lightburn, including the two brass inserts, but these were exported as .dxf files to be loaded into EZCad.
I was going to drill the holes for the inserts, but I didn’t have a bit of the correct size, so used the laser instead, one pass at 70% power and a speed of 100mm/s was good enough to go 3mm deep on a single pass.
A lovely finished result. I always like to see good finished work which does not look laser cut or engraved, but instead just looks like good careful work.
I think the brass inserts just finish this plaque perfectly, giving it considerable gravitas.
