Hi everyone
My question is what type of acrylic/plastic can I use with a 10w diode laser. And how can I check it to see if it OK to use
Thanks
Hi everyone
Thanks
Basically you can use almost all types of plastic but not PVC. The result will be very different, PP and PE…ABS and the like will melt without being able to see a result. You cannot cut acrylic with a normal diode if it is transparent, it has to do with the wavelength of this laser type, you should be able to process colored acrylic. But be prepared that most types of plastic smell terrible when processed with a laser, especially acrylic.
Here’s a short list
Typical 10 W diode results:
Polypropylene (PP)
Cuts cleanly and safely.
Slight edge melt but acceptable.
Used for stencils, storage bins, hinges.
Polyethylene (HDPE/LDPE)
Cuts, but melts more than PP.
Low smoke, non-chlorinated.
Technically cuts, but melts easily and may char.
Safe (no chlorine), but edges aren’t pretty.
Expect slow speeds and messy kerfs.
POM/Delrin (Acetal)
Cuts well.
Melts slightly but forms crisp edges.
Very common for gears and brackets.
PETG
Cuts with some melt-back.
Needs airflow to reduce stringing.
Popular for small brackets and craft panels
